1990 Pontiac Grand Prix Fuel Problem
GRANDPOOLPLAYER
  • 1990 PONTIAC GRAND PRIX
1990 Pontiac Grand Prix 6 cyl
I have no fuel getting to the motor. I have changed the filter & pump.
Sunday, July 26th, 2009 AT 9:27 AM
JDL
  • 16,098 POSTS
Hello, are there any codes? With the engine cranking, do you have spark at the plugs? No spark or injector pulse, I'd look for an rpm signal.
Sunday, July 26th, 2009 AT 9:44 AM
GRANDPOOLPLAYER
There is spark, and it has codes but I cant get the car any where to have it read.
Sunday, July 26th, 2009 AT 9:57 AM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_aldl_21.jpg
Your obd1, you should be able to check codes yourself. Use a jumper wire between terminals A & B of the datalink connector, turn the key to on, no crank, the check engine lite starts flashing, you count the flashes to get the codes.
Sunday, July 26th, 2009 AT 11:09 AM
PHANTOM01
  • 79 POSTS
Did you check the fuse and relay?
Sunday, July 26th, 2009 AT 2:31 PM
Related General Content
