1990 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
After replacing the brake booster, the brake lights will not shut off. If I unhook the brake light switch lever from the pedal pin, I can move it far enough to the rear so that the lights will shut off. In this position, it is about 1/2 inch out of place. Our Chilton's manual implies the switch is adjustable, but gives no info on adjustment. Any info?
Tuesday, February 16th, 2010 AT 10:40 PM
