When was the last tune-up?
Misfiring may be due to a vacuum leak, but it can also be caused by dirty fuel injectors, a weak fuel pump (low fuel pressure) or a faulty fuel pressure regulator. It can also be caused my ignition misfire due to worn or fouled spark plugs, bad spark plug wires, or weak ignition coil.
SPONSORED LINKS
Thursday, December 4th, 2008 AT 2:03 PM
