Popping noise from under car
SHAFTY2006
  • PONTIAC GRAND AM
I have a 01 Grand AM GT, with 176,000135,000 km, and 3.4 V6 engine.
When my I apply my brakes, there is a loud "pop" noise underneath the car. This noise only happens when the brakes are initially applied. It will not happen again until I resume travel and apply the brakes again. I am getting quite worried about this issue as I just purchased the vechile 1 month ago.
Any help or guidance would be greatly appriciated.
Saturday, October 6th, 2007 AT 9:08 PM
JONESJT
  • 7 POSTS
My wifes 1993 Pontiac Grand Am, 130k miles, had similar symptoms. There was a popping sound coming from the front suspension area. It didn't always happen but when it did, it was during braking, a turn, or going over a bump. After inspecting the suspension, realized that the stabilizer link bolts were broken, and the popping noise was the broken pieces of the bolt (part still attached to the stabilizer, part still attached to the lower control arm) being forced onto eachother hard enough until they slipped, and the upper piece would then smash into the lower control arm. Replaced link bolts ( $20.00) and not only fixed the problem, but the car handles sooo much better now. The broken bolts weren't as easy to see as you might think, depending on the position of them. If the two broken pieces were pushed together they still looked whole at first glance (although extremely corroded/rusted). Upon closer inspection, however, it was easy to see the separation. Putting the vehicle on a jack made it even easier to spot, as this drops the lower control arms and pulls the two pieces of the bolts apart.
Tuesday, October 30th, 2007 AT 8:13 AM
