MAF Sensor
SHORTYANGEL886
Hi, I have a 1995 Grand Am with a 3100 EFI engine. My husband did a diagnostic test on it, and the code said MAF/MAP Sensor. Where in the car are those sensors? They are not in their usual spot by the air filter. Please, can you help us?
Jun 20, 2007 at 1:44 AM
TBDK
  • 24 POSTS
Not sure about a MAP sensor position. The MAF sensor has to be somewhere in the air intake hoses. It measures the air flow into the motor(As you no doubt knew) so it has to be somewhere between the air filter and intake manifold. Some models don't have a MAP sensor. I'm pretty sure the 95 has 1 though. 1 way to check is call your nearest auto parts store and ask them to try and find it. If they can't find 1 of them for your year/make/model then your car doesn't have 1.
Jun 22, 2007 at 2:43 PM
