Hi i am having an issue with my 99 Grand Am. It has a 3.4L V6 3400 engine, with approx. 87k Miles. Here is information on what we've diagnosed so far
Engine Code:
P0300 Random/Multiple Cylinder Misfire Detected
- Changed the Spark Plugs, Wires, and Coil Pack with no result
- The car skips and backfires, and won't go much above 2000 RPM's then sounds like it's sucking down air.
- Won't go down the road above 10-15 MPH, and starts sputtering and skipping, esp uphill.
other known issues involved with the above code are:
EGR Valve
Catalytic Converter
Fuel Injectors
Exhaust Valves
If you know what may be causing my problem, have more questions, or have an answer, please respond, or email me @ schicherchia@aol.com. you can also reach me on aim if i am not away, my sn is schicherchia. Thanks
Engine Code:
EGR Valve
Catalytic Converter
Fuel Injectors
Exhaust Valves
Oct 13, 2007 at 10:25 AM
