eMail: ut4jc@yahoo.com
1996 Pontiac Grand Am P0140
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
Some quick O2 facts.
~ O2 sensors generate their own voltage as far as the PCM is concerned.
~ Sensor 2 has no affect on the air/fuel mixture.
Check the O2 @ the exhaust manifold. Suspect the cat is bad again.
There are a lot of folks that help thru this forum. Some pros, some retired pros, some soon to be pros (students), some home mechs that are here to help and learn, like myself. All made possible thru our sponsors. Support them if you can. What the heck, hit them up for a donation too. :)
The best way to get advice is to post in the proper forum section.
GM in this case. https://www.2carpros.com/forum/general-motors-repair-questions-vf9.html
Also when threads posted in any section are replied to an e-mail is automatically generated. It is then sent to all posters of the thread.
Good luck with the Grand Am and your ministry. Let us know how it goes. 8)
The oxygen sensor (O2S) consists of a zirconia electrolyte between two platinum plates. When the sensor reaches approximately 318ºC (600ºF) it becomes an electrical source that responds to the oxygen content in the exhaust. The PCM produces a bias voltage of approximately 450 millivolts on the oxygen sensor circuit. When the sensor is cold its internal resistance is extremely high, therefore the PCM recognizes the bias as an open circuit. As the sensor warms
up, the internal resistance decreases. When the sensor reaches approximately 318ºC (600ºF), it starts producing a voltage based on the oxygen content in the exhaust system. This voltage is used by the PCM to determine a rich or lean oxygen sensor signal and adjusts the fuel mixture accordingly.
This was written in regards to OBDI Saturns. Seems to fit your GM issue. Did you check the heater circuit for that rear O2?
Goo luck and post back. :)
Suggested Repair
Treat the steady 0.440 V reading as normal PCM bias voltage, which can remain with the sensor unplugged or cold. Check the downstream O2 heater circuit, and inspect the catalytic converter, which may have been damaged by the earlier rich condition.
Conversation Summary
A 1996 Pontiac Grand Am 2.4 had P0140 after blowing black smoke from a bad fuel pressure regulator. Replacing the regulator, plugs, and downstream O2 sensor restored drivability, but P0140 returned. Scan data stayed near 0.440 V even with the sensor unplugged, and wiring checks found no short. Experts explained that the PCM applies about 450 mV of bias on the O2 circuit, so that reading does not prove the PCM is bad. They advised checking the rear O2 heater circuit and suspecting a damaged catalytic converter.
