2005 Pontiac Grand Am
FRED RUNYON
  • 2005 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 56,287 MILES
THE CAR WILL NOT TURN OVER, EVEN THOUGH I REMOVED THE BATTERY AND HAD IT CHARGED AND LOAD TESTED.I ALSO CAN HEAR A HUMMING NOISE FROM THE VICINITY OF THE STARTER WHEN THE KEY IS TURNED
Tuesday, March 3rd, 2009 AT 7:48 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops.
Tuesday, March 3rd, 2009 AT 7:49 AM
