2005 Pontiac Grand Am
DLG455
  • 2005 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 45,000 MILES
Has a whining/humming sound when accelerating. Noise continues at driving speed.
Also, noise from front when turning left.
Thursday, July 30th, 2009 AT 7:39 AM
MMPRINCE4000
  • 8,548 POSTS
Check front CV joint boots for leaks/rips/tears. This may be the noise while turning.
The humming could be a hub assy. Try This:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Friday, July 31st, 2009 AT 8:25 AM
