It needs to go on a scanner so that you can watch the wheel speed at that wheel to see if it isnt getting signal. Could be damaged wiring, bad ABS controller, many different things. You dont have to go to the dealer, find a reputable shop in your area with the proper scan tool and they should be able to help you out
SPONSORED LINKS
Friday, February 5th, 2010 AT 7:45 AM
