2001 Pontiac Grand Am FUEL PUMP
2001 PONTIAC GRAND AM
110,938 MILES • 4 CYL • 2WD • AUTOMATIC
CORETTA
car want start turning over,but not getting gas to the engine
May 13, 2009 at 7:06 PM
GRANDAM1
  • 11 POSTS
is the car not turning over at all or is not starting, it could be you fuel pump or the cumputer not working the injectors, try this under the hood there is a black fuse box that has fuse on it take the 2 covers off and look on the side of the fuse box and it should show which fuse is for what, the one you are lookin for should say this f/p injr locate that fuse, pull it and see if its blowed if so replace it and LMK.....
May 14, 2009 at 10:11 AM
