2001 Pontiac Grand Am Cruise Control
2001 PONTIAC GRAND AM
181,200 MILES • 4 CYL • FWD • AUTOMATIC
JOHNNYRIMES
My cruise control doesn't work, but the cruise light in the instrument cluster comes on when I start the car, and the cight on the on/off switch in the steering wheel comes on when I turn the cruise control on, but it will not set no matter what spped I'm going. I've already checked all the fuses that have to do with the cruise control, but I'm not sure if their is a relay for it, because I don't have an owners manual. What could be the reason for my cruise control not working?
Apr 23, 2009 at 8:48 AM
GRANDAM1
  • 11 POSTS
usally when somethin goes bad on these cars the light of which will come on and stay on to let you know that it is not fuctional. for example if you are really low on brake fliud the brake light will come on and stay on to let you know to check you brake fluid most people get confused and think its the parking brake. but your cruise control itself is not working is what the cumputer is trying to tell you.. i had this problem!!
May 14, 2009 at 4:11 AM
