1999 Pontiac Grand Am P0507 Idle Control System RPM Higher
TROY0007
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 210,000 MILES
1999 Pontiac Grand Am 2.4L SFI DOHC 4cyl
when I come to a complete stop the rpms drop for a split second and then the engine starts to shack/run ruff. And when I shut the car off it shut off ruff.
when I am driving between the speeds of 20 to 40mph my RPMs get jumpy only if I am not pushing the gas peddle
P0507 Idle Control System RPM Higher Than Expected
Sunday, March 22nd, 2009 AT 7:51 AM
MMPRINCE4000
  • 8,548 POSTS
Remove and clean the IAC (Idle Air Control valve) both base and pintle. They can get clogged up and not operate properly.
If problem persists, remove and clean EGR valve, both base and pintle. EGR flow at idle will cause stalling, lower rpm and rough idleing.
IAC
https://www.2carpros.com/forum/automotive_pictures/108325_GA_IAC_1.jpg
EGR
https://www.2carpros.com/forum/automotive_pictures/108325_GA_EGR_1.jpg
Sunday, March 22nd, 2009 AT 8:50 AM
TROY0007
My engine does not have an EGR valve(check at pontiac dealship) and my Idle Air Control valve is 4 days old(new) and I have been driving the car long enough to let the PCM reset the iac but I am still having problems with the idle.
Could it be that the TPS(Throttle Position Sensor) is bad, or MAF sensor/o2 sensor
Sunday, March 22nd, 2009 AT 9:00 AM
MMPRINCE4000
  • 8,548 POSTS
Yes could be all three or one/two.
It is best to view sensor data on scanner in live data mode. View values of each sensor, it is much easier to isolate the problem rather than spending unnecessary money on parts.
Monday, March 23rd, 2009 AT 6:25 AM
