1999 Pontiac Grand Am fan heating/cooling speed
CASOTTO2003
  • 1999 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 135,000 MILES
becouse the fan selector speed switch works only on speed 3-4 and 5(leeving speed 1 and 2 inoperative), I beleive that one or more of the resistor in the "resistor-bank iis either burned or opened.
Would you kindly direct me to the location of the resistor-bank?
. And if I am wrong what other could cause the malfuncioning of the "speed control swith"?
Thank-you
Friday, March 28th, 2008 AT 3:51 PM
MASTERTECHTIM
  • 4,750 POSTS
Yes the problem is a burned up resistor. The new resister is redesigned to be alot more resistant to heat. Its located under passengers side of dash right next to the blower motor
Friday, March 28th, 2008 AT 3:54 PM
CASOTTO2003
I have already checked behind the glove compartment by the blower fan with no success!
Could you be more specific?
Thank you again.
Friday, March 28th, 2008 AT 4:05 PM
MASTERTECHTIM
  • 4,750 POSTS
Under dash. Close to firewall. Its the only thing that has wires going to it. Its held in by 3 little screws. Approx 6 inches from the passenger side in
Friday, March 28th, 2008 AT 4:53 PM
