HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Electrical
BCM
1999 Pontiac Grand Am Body control Module
GHOOPS
MEMBER
1999 PONTIAC GRAND AM
Computer problem
1999 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 105k miles
I am having the service vehicle soon light come on and I cant get anyone to find out whats wrong. Can you help me
Tuesday, August 4th, 2009 AT 12:16 PM
MMPRINCE4000
MECHANIC
There are 4 codes that can be generated "P" "C" "B" and "U". Most scanners only scan "P" Powertrain codes.
You will most likely have to go to a garage to get the "B" Body and "C" Chassis codes extracted.
Wednesday, August 5th, 2009 AT 7:55 AM
Please
login
or
register
to post a reply.
Related Electrical BCM Content
2002 Pontiac Grand Am Body Control Module
My Car Starts But Anything On The Dash Board Such As Spedometer, Gas Gauge, Heat Gauge Needles Will Not Move. My Mechanic Mentioned It Was...
Asked by
mamabear03
1 ANSWER
2002
PONTIAC GRAND AM
GUIDE
BCM Replacement
As with any computer, components inside the unit can go bad such as a transistor, IC or resistor. Subject to vibration, heat, coldness and moisture the BCM is built to...
Can I Water Proof The Body Control Module
Is Thier Away To Relocate Or Seal The Grand Am Body Control Module So It Will Not Get Water Damage Again If So Is Their Kit To Do It It On...
Asked by
Darrellc85
1 ANSWER
2 IMAGES
2001
PONTIAC GRAND AM
2000 Pontiac Grand Am Electrical
2000 Pontiac Grand Am 6 Cyl Two Wheel Drive Automatic Hi My Speedometer Cluster, Heating/ac Cluster, And Windows Dont Work Until The...
Asked by
tdub70
1 ANSWER
2000
PONTIAC GRAND AM
1999 Pontiac Grand Am Battery/alternator
Last September I Bought A New Alternator And Just Recently, My Battery Went Bad And The Car Wouldn't Start. I Bought A New Battery And Put...
Asked by
Shedrick20
1999
PONTIAC GRAND AM
How Many Amps For Alternator?
How Many Watts Does The Engine Produce While Idling? I Was Thinking Of Using My Car As A Generator Since My Frame Is Croaked, And It's...
Asked by
hackerssuck1
1999
PONTIAC GRAND AM
VIEW MORE
How to Read Codes
Is it Safe to Drive Check Engine Light?
Code Read Retrieval/Clear Mercedes Benz
