Usually when there is a problem with the alternator, a battery light will come on on the dash. If the car has an ammeter, or battery gauge, it will show low or in the red if there is a problem with charging. I would test voltage on the battery when the car is running, should be 14 volts +/-. It sounds like it could be a fuel problem, perhaps the pump is failing.
SPONSORED LINKS
Wednesday, July 30th, 2008 AT 9:29 PM
