1997 Pontiac Grand Am Stuttering at first
GRAND AM I CONFUSED
  • 1997 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
My grand am has been running great until recently. Whenever my car is off for a few hours and I go to start it up, it is very rough to start and sometimes stalls. Altough the second try it normally starts right up. Could this be a fuel injector problem?
Thursday, June 10th, 2010 AT 12:03 AM
BLACKOP555
  • 10,371 POSTS
I would check to make sure that the vehicle is holding its fuel pressure for extended periods of car off and make sure before its started that vehicle fuel pressure is holding good.
Try this.
Turn key on wait for pump to turn off then turn key off back on and repeat 4 times then try to start. Fire right up?
Thursday, June 10th, 2010 AT 9:52 PM
GRAND AM I CONFUSED
  • 6 POSTS
Im thinking the coil may be bad, I dont have a tester but im gonna try that
Tuesday, June 15th, 2010 AT 9:50 PM
BLACKOP555
  • 10,371 POSTS
Alright. But a coil normally doesnt behave that way. Let me know how it goes
Tuesday, June 15th, 2010 AT 9:52 PM
GRAND AM I CONFUSED
  • 6 POSTS
What do I have to do if the fuel pressure isnt holding up? Change the injectors?
Tuesday, June 22nd, 2010 AT 11:13 AM
BLACKOP555
  • 10,371 POSTS
After pump primes pinch off the return line. Does it hold?
If it holds pump up pressure again and pinch off the in line. Does it hold?
If neither way holds its the injectors.
Tuesday, June 22nd, 2010 AT 11:35 AM
GRAND AM I CONFUSED
  • 6 POSTS
Well I tested my fuel pressure and it was down to 30. I changed the fuel filter and helped but still did the same thing once in awhile. May test the fuel pressure one more time otherwise its probably the fuel pump. Great $300 fix haha
Thursday, July 1st, 2010 AT 9:12 PM
BLACKOP555
  • 10,371 POSTS
Sorry to hear that you may need a new pump. I wouldnt get a cheap pump or you may be replacing it again in a few years if your lucky.
Thursday, July 8th, 2010 AT 12:25 PM
GRAND AM I CONFUSED
  • 6 POSTS
Ya I ended up spending $275 on that fuel pump and sure enough my problem was fixed. Damn this car is getting expensive haha
Saturday, July 24th, 2010 AT 7:44 AM
BLACKOP555
  • 10,371 POSTS
Expensive. But at least it runs now. After everythings fixed its gonna be a brand new car.
Sunday, July 25th, 2010 AT 8:29 AM
GRAND AM I CONFUSED
  • 6 POSTS
It is a new car basically lol. New serpentine belt, new exhaust, new alternator, new fuel pump, new water pump, new thermstat, new timing gears/chain, all with lifetime warranties on the parts lol. All I need now is engine a few plugs and wires and a transmission haha
Sunday, July 25th, 2010 AT 10:18 AM
