1996 Pontiac Grand Am runs rough
RANDAVI
  • 1996 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 120,000 MILES
Car has an intermittent miss at idle. Car starts missing at speed and will sometimes run great. Also car will miss if you take sharp curve.
Wednesday, April 21st, 2010 AT 2:05 PM
Hi randavi, Welcome to 2carpros and TY for the donation
Do you have a check engine light and when was the last tune-up?
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
Wednesday, April 21st, 2010 AT 2:14 PM
