1996 Pontiac Grand Am
LEAD
  • 1996 PONTIAC GRAND AM
  • 6 CYL
  • 4WD
  • 236,456 MILES
I have no heat mechanics have tested the heatercore thermostat waterpump and blowers my system has been flushed out many times. Everything seems to be functioning but no one can find the problem can you please help.
Thursday, February 5th, 2009 AT 10:09 AM
JDL
  • 16,098 POSTS
Is it extremely cold in your area? Does the vehicle reach operating temp? Are the heater hoses hot?
Thursday, February 5th, 2009 AT 10:16 AM
LEAD
Yes its cold! And yes my hoses are getting hot and cold air is coming out of the vents. So far everything is registering good just no heat from vents all cold air. Have 2 mechanics scratching their heads they dont know.
Thursday, February 5th, 2009 AT 11:19 AM
JDL
  • 16,098 POSTS
Usually there are doors that open and close, depending on whether your using ac or heater. Maybe one of those isn't letting air go across the heater core, only.
Thursday, February 5th, 2009 AT 12:33 PM
LEAD
The last mechanic thought it was the doors also but apparently it checked out fine 2 mechanics looked at my car and did the same exact things to my car and found nothing someone told me it may be a relay swith. But one of the mechanics said it wouldnt have anything to do with the heat. Also asked him if it could be a fuse ihave bad fuses he said no.
Thursday, February 5th, 2009 AT 1:59 PM
JDL
  • 16,098 POSTS
If the blower motor works ok, I don't think it is a fuse.
There is a temp control cable that goes to an actuator, that's where I'd start looking. The database I was looking at doesn't show enough about that actuator?
Thursday, February 5th, 2009 AT 3:17 PM
LEAD
Hey thanks for the info. Will check it out. Thankyou for your time. Have a great night.
Thursday, February 5th, 2009 AT 8:10 PM
