HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine Cooling
Water Pump
SPONSORED LINKS
1995 Pontiac Grand Am Repalce water pump
DLJATW
MEMBER
1995 PONTIAC GRAND AM
Engine Cooling problem
1995 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
Is it easier to take the starter off or manifold off to access water pump.
Saturday, April 4th, 2009 AT 2:27 PM
BLACKOP555
MECHANIC
Take off the wheel and then take of the inner part of the fender skirt and you should be right too it!
SPONSORED LINKS
Saturday, April 4th, 2009 AT 10:16 PM
DLJATW
MEMBER
Good thing I didn't pay for this answer cuz you are wrong. It was right under the exhaust manifold
Saturday, April 4th, 2009 AT 10:24 PM
BLACKOP555
MECHANIC
Thats how I take it off. I am not wrong thats just my technique.
You do not have to be rude and tell me im wrong.
If you were so smart why would you even ask the question or think you have to remove the starter or the manifold? Hahaahh
Saturday, April 4th, 2009 AT 11:07 PM
Please
login
or
register
to post a reply.
Related Water Pump Content
I Need The Diagram Of The Water Pump And Thermostat...
I Need To See Where The Valve Is To Release Air From The System. I Also Need To Know What Will Cause This Car To Put Steam And Antifreeze...
Asked by
woogy
1 ANSWER
1997
PONTIAC GRAND AM
GUIDE
Water Pump Symptoms
The water pump is designed with a weep hole to allow coolant to leak from its housing before it can reach the shaft bearing which will cause the shaft to lock up and stop...
1996 Pontiac Grand Am Antifreeze
I Found Antifreeze On Ground I Am Putting Antifreeze In Everyother Day. Therei Is No Milky Loooking In Oil. Told It Might Be Water Pump...
Asked by
bethr1
1 ANSWER
1996
PONTIAC GRAND AM
1995 Pontiac Grand Am 4 Cylinder Automatic 2.3 112,000 Miles 2 Help! Please! Anyone! If I Sound Desperate, I Am. Heres The...
Asked by
jeffleeper
1 ANSWER
1995
PONTIAC GRAND AM
Thermostat Replacement
Where Is The Thermostat Located And How Do I Replace It? The Car Overheats And Jerks When I Try To Drive It Help
Asked by
Blkdrgn66
12 IMAGES
2005
PONTIAC GRAND AM
Thermostat Location And Replacement ?
1996 Pontiac Grand Am Se 2.4l Quad 4: Im Trying To Find The Location Of The Thermostat. Ive Gotten A "bible" For The Car But I...
Asked by
crystalgolem420
9 IMAGES
1996
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Water Pump Replacement
Water Pump
Online car repair manuals
