1995 Pontiac Grand Am Drive & park at same time
77,000 MILES • 6 CYL • FWD • AUTOMATIC
DADDYRIC29
Runs good when I shilt from park to r or drive car acts like it is in gear and park at same time if I rev it up and drop it into drive some times it will pop and go into gear and drives out fine but as soon as I put it in r or park I have the same problem. I have change trans fliud and now how side cover off but now I'm lost..........any help.
Ric
Oct 1, 2008 at 9:05 AM
MMPRINCE4000
  • 8,548 POSTS
Check the linkage to the trans. Have someone move the shifter while you watch the cable. The cable could be loose or binding.
If it checks out, you more than likely have some debris in the valve body/bad pump/govenor and will have to get it to a trans. shop.
Oct 2, 2008 at 12:50 AM
2CARPRO JACK
  • 11,533 POSTS
With the car in neutral on flat ground , does it roll ok back and forth if it is pushed? just want to make sure it isnt something at the wheels stopping it from moving in D.If it rolls ok, it sounds like something in the trans is broken or is about to give it up and you probably wont be able to fix it in th edriveway. The trans will have to come out of the car and be taken apart to find the problem
DADDYRIC29
The problem ended up to be the rod that will push the park paw into the gear. On the end of the rod GM mushrooms the rod to hold the spring loaded part in place...well the mushroom part wore off so when you tryed to put car in R it would not pull the part out far enough but if you went to Drive it would move alitttle and when the RPM's came up it would pop back and let the car drive. Car is back together now and work's fine. I did this in my driveway took two days but it was worth it. Hope this helps someone out.
Daddyric
Oct 9, 2008 at 11:03 PM
2CARPRO JACK
  • 11,533 POSTS
Good find.
Oct 10, 2008 at 12:36 AM
