1995 Pontiac Grand Am cylinders
1995 PONTIAC GRAND AM
94,000 MILES • 4 CYL • FWD • AUTOMATIC
MDTESTER
  • 11 POSTS
I changed the fuel pump and filter in my car about 2 weeks ago put it back together and drove it for about a week and it was fine. Then about a week ago I was driving down the road and it just lost power and got loud, so I pulled over and looked under it and the exhaust was red hot from front to back so i took it in and they changed the catilac converter and it still got red hot. so they pulled the plugs and changed them. It quieted it down some but it was still missing and only got red right by the catilac converter. So they checked the coil pack and that was good but cylinders 2 and 3 are not getting any spark. So they checked he ignition module and that is fine. We are stumped( thinking it could be wiring some where but nt sure. Do you have any suggestions? The coil housing and the timing also checked out fine.
Aug 30, 2010 at 11:27 AM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
I'm assuming this is a Quad4 engine and if it is what you need to do is replace the white coil housing. On that engine it acts as a distributor cap and cracks internally. I have seen it many times.
Aug 30, 2010 at 12:19 PM
MDTESTER
  • 11 POSTS
I called the shop and they said the coil pack and housing was good, any more ideas?
Aug 31, 2010 at 11:51 AM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
If they are so good why haven't they been able to fix it? I say change the housing.
Aug 31, 2010 at 11:58 AM
MDTESTER
  • 11 POSTS
I will give them a call again. Thanks for the info. I am at a loss and the thing is it just happened all of a sudden.
Aug 31, 2010 at 1:00 PM
MDTESTER
  • 11 POSTS
Just got off the phone with them again an they said they would give it a try. I told them that you were pretty sure that is what it is.
Aug 31, 2010 at 1:05 PM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
Let us know how it works out.
Aug 31, 2010 at 1:18 PM
MDTESTER
  • 11 POSTS
Thanks for all your help.. This morning I received a call telling me my car was fixed. When I picked it up, the guy just shook his head and says, yeah we were just saying... how often does are customer come and tell us whats wrong with there car... For all your help to me..They only charged me an hour labor. I guess what really made them shake there heads is I usually do all my own repairs on my vehicles and I am a Woman!!! Thanks again.
Sep 1, 2010 at 10:07 PM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
I'm glad it worked out for you. This is not the first time I've seen this problem and I knew it wasn't going to be obvious. Feedback is appreciated.
Sep 2, 2010 at 4:20 AM
