1995 Pontiac Grand Am brake system
DWAYNE GELEN
  • 1995 PONTIAC GRAND AM
  • 6 CYL
  • 165,000 MILES
Drive side front brake is sticky and won't take pressure off and brake will get hot on driver side from time to time
Tuesday, January 8th, 2008 AT 7:12 PM
  • 31,937 POSTS
Hi there,
Check that the caliper is not holding pressure when tight by cracking bleeder and seeing if it frees up, if so check for a restriction in the brake hose, if not a pressure problem O/Haul calliper and bleed system start there.
Mark (mhpautos)
Tuesday, January 8th, 2008 AT 8:12 PM
