1995 Pontiac Grand Am
SHYLASDAD
  • 1995 PONTIAC GRAND AM
  • 4 CYL
  • 124,000 MILES
THE CARS GETS HOT AND STALLS OUT WHY? MORE LESS IT GETS HOT AND YOU STALL OUT AND THEN YOU CAN PUSH IT TO THE SIDE OF THE ROAD LET IT SIT FOR A MINUTE OR TWO AND RESTART IT AND PUT IT IN GEAR AND IT DIES WHY?
Saturday, May 24th, 2008 AT 1:18 AM
MERLIN2021
  • 17,250 POSTS
Is the service engine soon light on?
https://www.2carpros.com/forum/automotive_pictures/62217_95_OlderGM_22.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
Saturday, May 24th, 2008 AT 5:28 AM
