1993 Pontiac Grand Am BRAKES
KEVIN M. GRIFFIN
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 98,000 MILES
THE RIGHT FRONT CALIPER IS STICKING. I HAVE REPLACED THE CALIPER, BRAKE PADS AND BLED THE BRAKES. I ALSO REMOVED THE NEW CALIPER, PUT ANTI-SEIZE ON THE BOLTS AND RE-INSTALLED. IT STILL STICKS. I BELIEVE IT'S THE MASTER CYCLINDER BECAUSE IT WILL NOT RELEASE WHEN THE KEY IS TURNED OFF, ONLY WHEN I BLEED THE PRESURE OFF OR OVER A PERIOD OF TIME.
Tuesday, December 25th, 2007 AT 5:33 PM
BMRFIXIT
  • 19,053 POSTS
Replace caliper flex hose
Tuesday, December 25th, 2007 AT 9:10 PM
