HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Interior
Gas Pedal
SPONSORED LINKS
1992 Pontiac Grand Am
FLYHIGHER
MEMBER
1992 PONTIAC GRAND AM
Shakes or Wobbles problem
1992 Pontiac Grand Am 4 cyl Manual 122000 miles
When I press down the gas peddle, My car shakes, like it's not getting enough gas. Could it be the fuel injectors
Tuesday, March 31st, 2009 AT 10:14 AM
MMPRINCE4000
MECHANIC
Before replacing parts, check fuel pressure with mechanical gauge, If OK then check injectors with noid light to see if they are pulsing.
If fuel is OK, then check spark. It is best to try and isolate problem rather than throw parts at it.
SPONSORED LINKS
Wednesday, April 1st, 2009 AT 8:51 AM
Please
login
or
register
to post a reply.
Related Gas Pedal Content
Grand Am Slows, Quits Running Then Can Start Back Up...
2001 Grand Am Se1 3.4l V6 All Of A Sudden Gas Pedal Has No Effect On The Engine, It Just Stalled Out. Pull Over To The Side And As I Do So...
Asked by
rwarner1
2000
PONTIAC GRAND AM
2001 Pontiac Grand Am
My Grand Am Is Having Problems When I Try To Accelerate It Acts Like Its Not Getting Fuel And When I Press The Gas Pedal Then All Of A...
Asked by
rriegel
2001
PONTIAC GRAND AM
2004 Pontiac Grand Am Leak
I Have A 2004 Pontiac Grand Am, Water Is Leaking From Something Under The Engine, I've Felt Around It As Much As I Possibly Could, And...
Asked by
MissOwlEyes24
2004
PONTIAC GRAND AM
Grand Am Problem
Loud Humming Noise When Coasting Down The Road Getting Load Faster You Go, Only When Off Gas Pedal
Asked by
edl0920
3 IMAGES
2006
PONTIAC GRAND AM
Higher Idle Seed
My '2000 Grand Am Has An 2.4l Engine And 78000 Miles. Recently, The Idle Speeds, Parking Idle And Driving Idle, Go Higher From Original...
Asked by
jzheng_GrandAM
1 ANSWER
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Check Engine Light
Code Read Retrieval/Clear
Code Read Retrieval/Clear Honda
Online car repair manuals
