Hi, have you done any basic testing? Have a helper crank it, while you check for spark at the plugs and injector pulse. If you have neither one, it's a good bet the computer doesn't see an rpm signal for some reason. The rpm signal comes from the crank sensor, to the ignition module, then to the computer.
Wednesday, February 18th, 2009 AT 9:37 AM
