Refueling
DANLEY
I just bought a 2006 Pontiac G6 convertible with 10,500 miles. V6 engine. I cannot seem to get gas in it. I have been to 3 different gas stations and its the same thing. The nozzle shuts off as if the tank is full. I get about .50 cents worth for each squeeze and then "kachunk". I move it around, further in, further out. Squeeze less, squeeze more. No luck. I wrestle with it until I finally get about $10 bucks worth of gas and then give up. Havent been back to the dealer yet, its still under warranty, but in case its something simple, thought I would check here first. Thanks for your time.
Nov 7, 2007 at 2:24 PM
MIKE H R
  • 3,094 POSTS
best bet is take it back to the dealer. It could be a hose that is crimpted and not letting the vapors vent.
Let them know what it does.
Nov 7, 2007 at 2:29 PM
FISHERMAN
  • 937 POSTS
[quote:4e34279f9b="Danley"]I just bought a 2006 Pontiac G6 convertible with 10,500 miles. V6 engine. I cannot seem to get gas in it. I have been to 3 different gas stations and its the same thing. The nozzle shuts off as if the tank is full. I get about .50 cents worth for each squeeze and then "kachunk". I move it around, further in, further out. Squeeze less, squeeze more. No luck. I wrestle with it until I finally get about $10 bucks worth of gas and then give up. Havent been back to the dealer yet, its still under warranty, but in case its something simple, thought I would check here first. Thanks for your time.[/quote:4e34279f9b]
Hello !
Well, looks like the hose that leads the gas to the tank its bend ... and the "gas" its "cutting" the nozzle..
could be something as simple as that !!
But..
I would make it check by the dealer... Has to be covered by the warranty..
anyhow let us know!
Good Luck!
Nov 7, 2007 at 2:32 PM
