My 2006 Pontiac G6 is intermittently shifting very hard between gears and between Park, reverse, and drive! It seems to be getting more common and is very prominent. My mechanic and I were able to hook it up to the computer while the issue was occurring and found that the Pressure Control Solenoid was not registering at all! When tested while not shifting hard it tested completely normal. The only code that is showing up is a Mass Air Flow Sensor code.. No transmission code. This is veeeery annoying and can't be good for the longevity of the tranny. The fluid is clean and shfits perfect when not acting up. The check engine light comes and goes. Please Help!!
Mar 2, 2010 at 4:07 PM
