Sometimes when the pretenioners go off they crack or break the small yellowc onnector attached to the seat belt itself.( I've replaced many of then) So tell him to take a good look at the connectors at the seat belts, that could be why the codes are setting.
If the connectors are Ok, I will need to have the specific codes that he is retrieving.
As far as why the right side is locked is a little strange.
A few things to check:
Make sure the seat belt hasn't been dropped.
Make sure it is installed correctly, it slides into a slot in body and needs to be level.
Make sure that they are new, and not from a scrap yard.
The fact that there is still codes coming up for the seat belts makes me think that something is not right with the r/s belt.
There is a little locking device inside the seat belt that sometimes gets stuck during transport. Tell him remove the belt, and shake it a bit while trying to get it to released, but it has to be level for it to release.
Let me know what you come up with on that.
Friday, February 26th, 2010 AT 12:01 PM
