2000 Pontiac Firebird DTC P0440 & DTC P0506
25,000 MILES • V8 • 2WD • MANUAL
DMARNES
When the "Service Engine Light" goes on a put a reading coding machine into the car's computer and generated the following two codes:
P0440 & P0506
Can you help me as to how can I fix the problems for these two codes with a local mechanics. Thanks you very much in advance
david
Sep 7, 2009 at 6:57 AM
BRIAN 1
  • 1,030 POSTS
p0506 is idle speed to low,try cleaning the throttle body first,see if that works,if not might have a problem with the IAC valve,p0440 is EVAP system,check the following first, A loose, incorrect, defective or missing fuel tank cap.
• Disconnected, improperly routed, kinked or damaged EVAP system purge lines.
• A damaged EVAP system component.
• A loose, missing, or damaged service port dust cap and/or schrader valve. if this test ok then use a scan tool to command the vent and purge solenoid on/off to see if it works,if not have the evap sys smoked for any leaks.
Sep 7, 2009 at 7:04 AM
