1997 Pontiac Firebird
1997 PONTIAC FIREBIRD
CRAZYMAN200368
Electrical problem
1997 Pontiac Firebird 4 cyl
WHERE IS THE RESET BUTTON LOCATED IN THIS VEHICLE?
Mar 11, 2010 at 4:10 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Hi, what's the problem, any driveability issues. Need more info. There is no reset button, that I'm aware of. If the vehicle cranks good, but, won't start, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure.
Mar 11, 2010 at 4:20 PM
There is no inertia switch/fuel cut off switch on this vehicle.
