I need some advice. I think I am on the right track. Currently when I start the car cold, the idle does not run and stalls. When I give alittle gas it will run at 2000 rpm most of the time and some times falls on its face. It will drop in RPM sharply or sometimes misfire. I did the common code retrieve with the jumper. I recieve a lean code off the O2 sensor and a MAF code. I did a pressure test on the fuel rail is it is fine. I did a flow check at the fuel rail and I get more than a pint at 30 seconds. I replaced the MAF sensor, checked every vacuum I could find and replaced questionable ones. I went ahead and changed out the O2 sensor for the heck of it. It ran ok for a very short period of time and the problems came back. I tried to find air leaks in on the manifold and currently do not see anything. I am thinking it could be a hard to find manifold gasket leak or possible faulty injector. Is that sound reasonable? Would a gasket leak set off a MAF sensor? I check numerous connections and all the grounds I can find. Please help.
Mar 3, 2010 at 8:46 PM
