Hi adobepeak1, Welcome to 2carpros and TY for the donation
Swap the fuel pump relay with a relay similar to it and turn key on-do you hear the fuel pump if not -jumper the tan and white wire to the orange wire on the fuel pump relay connector socket-turn key on -do you hear it-if not the problem could be the relay ground, fuel pump control and battery circuit of the computer or the fuel pump ground circuit-
SPONSORED LINKS
Thursday, September 9th, 2010 AT 7:31 PM
