Hello –
I need some more specifics on your vehicle to better assist you. Is your vehicle just a Firebird, or a Firebird Formula, Firebird Trans AM, or Trans AM GTA? Also, I need the engine size in liter and the 8th digit of your VIN.
Just a couple of questions to get on the same page. Why did you replace the starter and alternator?
So if I understand, the car was running just fine….you replace the starter and alternator and now it is doing this?
Next, if it is drivable, please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Now I know you just replace the alternator but I want to see how it is reacting with the battery and in the car.
If you can not drive it….then you can check the code scanner out from AZ and check the codes yourself and then please let me know the info above.
We need to figure out if it is electrical or fuel related. Pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. Don’t have your hands on any part of the metal!!! If there is no spark, then it is electrical. If you are getting good spark then you need to get a fuel pressure check on the fuel pump to ensure it is putting out okay.
Do the above and please get back with me.
Dec 6, 2008 at 4:41 PM
