1968 Pontiac Catalina pedal hits the floor
BOBHALL
Brakes problem
1968 Pontiac Catalina V8 Two Wheel Drive Automatic high miles
I have replace the brak pads, one brak line,booster, master cylinder, bled the brakes, have brak fluit but the pedal still hits the flood
Jul 12, 2009 at 2:25 AM
HMAC300
  • 48,601 POSTS
first see if your pedal wil pump up at all. If it doesn't your master cylinder may need to be rebuilt or a new one . then go about bleeding the entire system, starting at right rear then left then right front and finally left. You can rent a pressure bleeder so you don't need any help. That should fix your problem.
Nov 1, 2009 at 1:44 AM
