cv joint repair
PONTIAC BONNEVILLE
DAVE JESSOP
Hello, i have a 1994 pontiac boneville with a 3.8 litre engine with 234,000 km.s..........i am doing the front brakes and noticed the drivers side cv joint is split (closest to the brake rotor) I was wondering what this project involved............Thanks davej.
Oct 28, 2007 at 2:24 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
The best way is to replace the axle. Unless the boot has just recently opened up. A manual will help:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
The ball joint needs to be separated, the axle nut removed. With the ball joint disconnected, the spindle can be moved forward and the axle removed.
Oct 28, 2007 at 5:10 PM
