'93 Bonneville, hesitates and now RPM's gone wild
SERDA23
  • 1993 PONTIAC BONNEVILLE
1993 Pontiac Bonneville, 117,000 miles, V6 3.8 Liter
For a while now the car has to "warm up" regardless of the temperature outside before it will run right the first time it is started in the day. If you don't wait for it to warm up and try to go it will hesitate, and doesn't gain speed, will drive jerkily.
On the way home tonight, it was running fine until:
I was coming downhill and I hit about 55-60 mph and the car started jerking, and I noticed the RPM's going up and down like crazy. I was less than a mile from home so I kept going, and when I turned off the engine I noticed what was either a tiny bit of smoke or steam coming from under the hood.
Any ideas?
Thursday, February 1st, 2007 AT 4:59 PM
SERDA23
It was a transmission fluid leak. Needed to get a hose replaced, and it's all good! Well, the car still needs to warm up before the first drive of the day, but I guess that's just it's special quirk. :)
Wednesday, June 13th, 2007 AT 7:11 AM
Related Engine Hesitate Content
