2003 Pontiac Bonneville Steering Knock
DXN238
2003 Pontiac Bonneville with 80,000 miles. I hear and feel a knocking noise when turning steering wheel in either direction. I had the intermediate steering shaft replaced about 7500 miles ago and the noise went away, but now it's back. Any advise would be appreciated. Thanks
Jun 27, 2006 at 3:15 PM
LSUSSEL
  • 252 POSTS
Check the rack of pinion or the power steering fluid level.
Jul 1, 2006 at 10:24 AM
SLAV84
  • 7 POSTS
there's a technical service bulletin on this. the issue seems to be the intermediate shaft. i've heard it doesn't need replaced but needs to be lubricated. pontiac sells a 15 dollar kit to do it, but it's a 1.5 hour job. either way it apparently doesn't solve the problem forever. the sound comes back. i'm told it's an annoyance, not a safety issue, but i'm not a mechanic and so don't take my word on it.
Mar 12, 2008 at 2:41 PM
Suggested Repair
Check the power steering fluid level and inspect the rack and pinion for the knocking noise when turning.
Conversation Summary
The owner of a 2003 Pontiac Bonneville with 80,000 miles reports a knocking noise felt when turning the steering wheel in either direction. The intermediate steering shaft was replaced about 7,500 miles earlier and the noise returned. An expert advised checking the rack and pinion or the power steering fluid level. Another owner mentioned a bulletin about lubricating the intermediate shaft, saying the noise can return and may be an annoyance rather than a confirmed safety issue.
