If the SES light is not on, You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If SES is on, read the codes! Autozone does it free.
SPONSORED LINKS
Monday, November 5th, 2018 AT 7:07 PM
