1999 Pontiac Bonneville Check Engine Light ON
WSHRIVER
  • 1999 PONTIAC BONNEVILLE
  • 6 CYL
  • 100,000 MILES
I was told I have a leak in my fuel tank and filler neck and that is causing my problem - I need to know how much it should cost to replace my fuel tank and filler neck - I was quoated $600.
Thursday, October 1st, 2009 AT 10:54 AM
KHLOW2008
  • 41,814 POSTS
Hi wshriver,
Thank you for the donation.
The price quoted is reasonable as the fuel tank is listed at $482.97 for normally aspirated engines and $ 466.73 for turbo charged engines.
The labor time is 1.8 hours which means it could be between $130 to $225 depending on the labor rate at your location.
The fuel filler neck price is not available in our database so I am not able to provide the cost.
Thursday, October 1st, 2009 AT 1:38 PM
