1999 Pontiac Bonneville
JEKSLK
  • 1999 PONTIAC BONNEVILLE
Engine Performance problem
1999 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
I am having a misfire under heavy acceleration what could be the cause?
Thursday, March 4th, 2010 AT 6:12 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug.
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
Thursday, March 4th, 2010 AT 6:15 PM
JEKSLK
I forgot to add I also hear a popping through the intake when it is misfiring
Thursday, March 4th, 2010 AT 6:18 PM
