1998 Pontiac Bonneville CYLINDER MISFIRING
MRBILL2U
  • 1998 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 132,000 MILES
I had my "check engine"light and was told that number one cylinder was misfiring.I have change the spark plugs but that hasn't solved the problem. What else could it be?
Sunday, December 7th, 2008 AT 3:21 PM
  • 109,755 POSTS
Hi:
It could be a problem with a plug wire, coil, or fuel injector. If you remove the plug, is it saturated with fuel? Can you feel the miss when driving and does it happen all the time or once in a while?
Sunday, December 14th, 2008 AT 12:14 PM
