1997 Pontiac Bonneville Security Light
GBCPREACHER
  • 1997 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 73,000 MILES
When I try to start the vehicle, the security light stays on and the engine will not even turn over. I wait about 5 minutes, the light goes out, USUALLY the car will then start and run fine. Often this process has to be repeated 2-3 times before the vehicle starts.
Monday, July 13th, 2009 AT 11:28 AM
SATEDPEACHES
I had the same problem with my 01 bonneville. I don't know if uve recieved any answers, but here it goes.
When I had mine taken in they said nothing was wrong bc they got it to start. Then, as soon as I got home it stopped! I would turn the key and the lights came on (so obviously it wasnt the battery)- even the air would turn on. I wouldnt hear it crank or roar. But I could hear like if something switched (like a click), but still couldnt get it to start. Long story short, it was the ignition switch!
You should def try to replace it or at least have someone look @ it for u
Saturday, August 1st, 2009 AT 6:41 PM
SATEDPEACHES
Another thing, u might want to have ur alarm system checked out (if it is equipped with one).
I dont know about your car (im assuming its the same as mine?) But I know with my car if the security system is defaulting the whole car will not work. Its equipped that way to decrease chances of being stolen.
Saturday, August 1st, 2009 AT 6:43 PM
