1997 Pontiac Bonneville
REKOGREASON
  • 1997 PONTIAC BONNEVILLE
Engine Mechanical problem
1997 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
im trying to put my belt back on my engine but the belt is not tight. What am I supposed to do?
Tuesday, May 19th, 2009 AT 5:37 PM
  • 109,885 POSTS
Either the belt is the incorrect one, the tensionier is bad, or you have it mis-routed. Is there still a lot ot tension from the tensionier? Are you sure it is routed correctly? Compare it to the old belt. Is it the same length?
Friday, May 29th, 2009 AT 7:29 AM
