I've replaced everything possible in this car the heater will not throw hot air, it does blow cold air. The latest thing I replaced was the Climate Control Unit, the day we replaced it we had heat the next day no heat. Like I said it's blowing cold air only. Any suggestions?
SPONSORED LINKS
Wednesday, January 30th, 2008 AT 7:59 PM
BMRFIXIT
MECHANIC
We don’t know what is it that you replaced
lets start with the basics
heater hoses are they both hot or not
did you check blend door operation?
SPONSORED LINKS
Wednesday, January 30th, 2008 AT 8:14 PM
BLACKOP555
MECHANIC
Both heater core hoses hot? I belive they probably are in your case its the blend door if they are both hot.
