1995 Pontiac Bonneville STALLING
JUICYANDLEATHER
  • 1995 PONTIAC BONNEVILLE
  • 6 CYL
  • 124,000 MILES
MY CAR STALLS. IVE REPLACE THE ECM AND THE ALT THE COIL PACKS AND IGNITION MODULE WHAT ELSE COULD IT BE
Sunday, March 21st, 2010 AT 5:10 PM
Could be a fuel or spark problem quit replacing things-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, March 22nd, 2010 AT 7:21 AM
