1995 Pontiac Bonneville
JOSH7220
  • 1995 PONTIAC BONNEVILLE
  • 6 CYL
  • 332,000 MILES
Hi my 95 bonne ssei when excel very slow there is no problem. When I get on it just a littli bit it cuts out shakes and makes a hell of a noise. Sounds like driver side. Worried it axel but dont know. Please help.
Friday, March 13th, 2009 AT 7:16 PM
  • 109,885 POSTS
Can you describe the noise? Does is happen on turns or only under heavy acceleration?
Friday, March 13th, 2009 AT 11:39 PM
JOSH7220
The noise is almost a chunky grind that pulses at moderate accel. And happens in turns also. How do I tell if drive axel? Thank you for your help.
Saturday, March 14th, 2009 AT 7:20 PM
  • 109,885 POSTS
It sounds like a bad CV joint. Lift the front of the car (safely) and grab the axles to see if there is play up and down at the joint.
Let me know what you find. Also, see if there is play at the weel too. This could be an bearing too.
Sunday, March 15th, 2009 AT 3:16 PM
