1994 Pontiac Bonneville Power steering goes off & on
1994 PONTIAC BONNEVILLE
15,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHARDZEMPEL
At slow speed recently, the dash lights lit up, there was a "bing" alarm sound, and the power steering quit, causing my son to pull off to the shoulder. He turned off the car and then turned it back on. When it came back on, the power steering seemed to work fine. He drove directly to a gas station and checked the engine. The fluid in the Power Steering reservoir was at a good level, The hoses are okay and so is the fan belt. I took it to our dealer and a new guy I don't know called me the next day and said the belt, pulley and reservoir are okay, but that a hose that leads to the rack & pinion has a small leak. He says the problem is a valve inside the rack & pinion needs to be replaced, and that it might shut down any time. To repair it they want over $1,100.
It all sounds okay to me except for the price. Are they accurate or trying to rip me off?
Jan 12, 2009 at 6:31 AM
JAMES W.
  • 2,394 POSTS
A "pinhole" leak won't destroy your rack and pinion unless you, and you obviously didn't, drove the car for a long time out of PS fluid. It sounds to me like, for some reason, the belt was slipping. If everything seems to work ok now, I would drive it for a while and see what happens. Also, for $1100, I would surely get a 2nd opinion. Hope this helps. Keep us posted.
Jan 12, 2009 at 7:09 AM
