1994 Pontiac Bonneville heater takes long toheat up
SSHERARD
  • 1994 PONTIAC BONNEVILLE
  • 6 CYL
  • 324,000 MILES
My heater takes along time to heat up I changed the thermometer and still will not heat up like it should I changed the cap
Tuesday, November 11th, 2008 AT 4:13 PM
MASTERTECHTIM
  • 4,750 POSTS
Check the hoses going to the3 heater core and see if they are hot, if one is hot then I would suspect a clogged heater core. Also if you can gain access to under the dash you can check to make sure the blend door is fully on hot. I check this by switching from hot to cold and see what door moves then make sure it goes fully in each direction
Tuesday, November 11th, 2008 AT 6:06 PM
